OPC Driver Mitsubishi FX1S
I want to communicate my Mitsubishi FX1S Series PLC with Labview 8.2, I installed Industrical Automation OPC server 5.1, when i try to configure my Mitsubishi PLC, OPC is Supporting Only FX-24MR.  After seleting FX-24MR, and configuring with OPC Server in Labview its not communicating.
Please Help me out.
Atif SarFraZ
(3,439 Views)
Hi Atif,
I would suggest first to install the patch for the IA OPC Server. If that does not work, could you be more specific about what you mean "not communicating"? Can you connect but the data is bad? Can you not connect at all? More details would help locate the exact problem. Thanks!
Stephanie
(3,427 Views)
