Omega CN7500 communication (ASCII protocol)
Chemist189,
nyc was referring to our Version Conversion page. Feel free to save the code and upload it to the discussion forum if you want to view it in LabVIEW 7.1. I must stress that johnsold has provided a good amount of information on this issue, so please feel free to indicate a specific question related to Omega CN7500 communication.
Best,
Jason M.
Message 11 of 38
(3,916 Views)
Thanks both, for informing me about the Version Conversion board - sorry, I'd somehow never been aware this existed. Thanks again.
Message 12 of 38
(3,902 Views)
Hi All,
I've taken much of ChE3208's code and developed a small instrument driver for the CN7500 temperature controller.  The instrument driver allows you to monitor the process value, set point value, and front panel LEDs from the controller.  It also allows you to send set point values to the device.  This instrument driver is setup to help you get started using the device and does not cover every functionality available on the controller.  I have included an example as well.  Please ensure your device's serial configuration matches the configuration in the code for the example to work correctly.
The attached instrument driver was created in LabVIEW 2012.  Please note this driver has not been verified by NI or Omega.  I can convert it to an older version if need be.
Hope these are able to help someone out.
Cory
Message 13 of 38
(3,871 Views)
Greetings.
I need this communication, but I have LabVIEW 2009, you can download the version.
  thanks
Message 14 of 38
(3,789 Views)
I am not sure if you meant to ask a question or stated a response. Please clarify.
Also, I would recommend generating a new thread as this one has been inactive for 5 months. New threads are actively monitored by forum members and can get a much faster response.
You can reference this thread in the new one.
Regards
Arham H
Message 15 of 38
(3,751 Views)
Sorry I have not answered sooner.  I assume you wanted me to convert the files to LV 2009.  Please see attached zip file and see if this works for you.  The files were saved for LabVIEW 8.6.
Hope this helps.
Message 16 of 38
(3,747 Views)
Hi, I was wondering if you could convert your driver to labview 9.0 as well.
Message 17 of 38
(3,597 Views)
Ignore this post, I just saw that it has already been addressed
Message 18 of 38
(3,595 Views)
Forgive me if this is an elementary question: I am using the Omega cn7500 hooked through an NI DAQ board. How would I tell the controler where to read and write from? (How would I specify in the program the physical channel that I have the temperature controler wired to?)
Message 19 of 38
(3,585 Views)
I don't think you can run the CN7500 through typical analog and digital I/O channels.  These temperature controllers communicate over RS485, so you will need to get an RS485 to RS232 converter (from B&B Electronics or other mfg.) to allow you to connect to your pc.
Message 20 of 38
(3,581 Views)
