Omron K3HB RS232 Communication
Morning All
I'm trying to alter an old program that was reading a Druck 282 DPI to read an Omron K3HB DPI over RS232. I have the coms string for the Omron (02H 01 00 0 0 0101 C0 0002 00 0001 03H), but it does not seem to be working. I've attached a screen grab of the code I'm working with.
Any help would be appreciated.
Andy
(5,052 Views)
Hi Andy,
Have you tried using this VI to test for a response from the Omron?
http://www.ni.com/example/27423/en/
Are you able to find the Omron as a VISA resource?
https://forums.ni.com/t5/Example-Code/Programmatically-Determine-Card-Information-in-PXI-Chassis-slo...
Let me know how you get on with these examples.
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(4,975 Views)
Hi Tim
I've run both programs. The VI for getting a response gave nothing, I was getting 0 bytes at the port. The one for VISA resources found nothing, generating an error at the VISA find resource node.
I guess from that the Omron is not communicating with VISA?
Andy
(4,947 Views)
Better post the vi instead of a png of the BD 😉
Seems that you need to send the hex values.
Have you set the display style of your string input to hex?
If not, do so 😉  by rigth click the string control and set it to hex display
Greetings from Germany
Henrik
LV since v3.1
(4,942 Views)
Hi Andy,
Have you tried following these steps for configuring a serial device?
https://learn.ni.com/learn/article/getting-started-with-instrument-control-hardware-and-labview
Cheers,
Tim, CLD, CTD
(4,939 Views)
