On/ off state detection with serial device
If that 9 pin connector is used for the instrument the op is aking about, not only is a com port on the pc incorrect, but there is no method for reading status. All pins are for control. Manual control would have to be disabled.
Message 11 of 13
(1,222 Views)
Thank you. I think that means I have to attack this problem in a different way but this answer does help.
Message 12 of 13
(1,196 Views)
Hi JoMu2015,
I am not clear from the history of the thread whether or not we know how the serial instrument represents the pump being off. Is there a specific query command that you can send whose response is whether or not the pump is on? Another potential issue is that, as someone described earlier, having a heating element controlled in software could be dangerous if the software crashes.
Basil
Applications Engineering
Message 13 of 13
(1,183 Views)
