Oscilloscope Connection
You'll need the manual to know how to set the different types of Ethernet interfaces unless you blindly stumble upon it when you browse the menu. Your Ethernet cable should be s cross-over type unless the pc or scope will auto-switch. I would recommend you use fixed ip for both the scope and the pc port. None of this initial setup is LabVIEW related.
Message 11 of 11
(2,406 Views)
