Our ENET works on one server OK and does not on another, even when the app that uses connection has been closed and the server is shut down...
We have one server with ENET on it, which works fine. Now we are setting up another server with ENET on it and this one does not work. We have tried everything and run out of ideas what to do. Will appreciate.
(3,880 Views)
What do you mean by "not work"? Does the port not open, is the data corrupted, no writes, no reads, etc.?
(3,880 Views)
The ports open, one data sample comes ok, and then we get just zero length strings from the port buffers.
However, when we move the app back to our old server it works fine again.
One would say there is something wrong with our new server setup or the network. Well, we compared the setup. It looks the same. I would appreciate if we got a phone number to call NI and give more details on our environment. That would surely help to resolve this issue in a more timely manner. Thanks in advance for your assistance.
(3,880 Views)
I'd like for you to work with our AE's to see if they can get you up and running. You can contact them at 800-433-3488.
(3,880 Views)
Also, are you using Win NT 4.0? If so, you must use at least Service Pack 4.
(3,880 Views)
