P70360 Stepper Driver - COM1 Setup Problem
I have a P70360 Stepper Driver connected to a NI Stepper Motor.  When I connect it to power, a green status light turns on.
I would like to configure the driver using the software rather than the DIP switches.  I downloaded the P7000 GUI/Firmware from the CD that came with the driver. I connected the driver to the computer using a serial connector.  I setup the COM1 settings with the settings from the manual.
When I pull up the P7000 Tools, it can not find the driver.
How do I configure the driver?  If I have to use the DIP switches, how do I test that its working before connecting it to a NI UMI board which connects to a NI Motion card?
(3,921 Views)
Hello Random,
According to the KB linked below, you should be able to configure the driver using both options ( switches and software), can you tell me how did you installed the software / drivers? Do you received any error numbers?
Configuring the P7000 Series Stepper Drives for the Correct Motor [link removed; article no longer available]
Warm regards
Mart G
(3,903 Views)
I don't get any error messages. I installed the P7000 Tools from the CD that came with the driver.
I did manage to get the DIP switches to work.  It is suggested that I use the P7000 Tools, so I would still like to know if there is a way to use them.
S1: 1
S2-1: Off
S2-2: On
S2-3: On
S2-4: On
S2-5: Off
S2-6: Off
S2-7: Off
S2-8: Off
S2-9: Off
S2-10: On
S2-11: On
S2-9: Off
(3,899 Views)
Hi Random,
Are you able to see the device if you configure the dip switches as outline on page 7 of this manual?  It details the location of the dip switches for using the P7000 tools software.
Kira T
(3,884 Views)
