The whole purpouse of that macro used with the DeviceIOControl function is to overwrite the setting in the Device Manager. The Device Manager won't show the change, but the board should work in the appropriate mode.
I've searched for know problems, but I couldn't find anything.
What OS are you using?,
What programming environment?,
What's the version of NI-Serial that you're using?
What's the error code you're getting?
If you configure the board in Device Manager for the 2 wires mode, does the program work correctly?
DiegoF
National Instruments.
