PCI 488 not recognized by computer
Hi, I have a NI488 GPIB board but the computer can't recognized it after I plugged in. I downloaded some drivers but it still can't connected rightly. I wonder which driver should I use? My opreating system is Win7 and I want to connect it with Keithley 2001 multimeter for the data record.
(5,177 Views)
Hi Bear2013,
Thanks for posting on the NI Discussion Forums!
You can use either the NI-488.2 driver for low-level GPIB functions or NI-VISA for a more high-level approach. You can find downloads for both at ni.com/downloads.
Which operating system are you using? Does the computer recognize at all that the device is plugged in?
(5,144 Views)
After taking a closer look at your pictures, I just want to make sure which card this is. Can you confirm the manufacturer and the part number? I don't see PCI-488.2 is not in the National Instruments product catalog.
(5,121 Views)
That is an old and now obsolete board from Measurement Computing. You may be able to still get the drivers:
http://www.mccdaq.com/
-AK2DM
(5,108 Views)
I I have the same problem, but I work with XP
to run MAX can not detect my GPIB
could give me a solution
(4,979 Views)
Hi elchido,
Do you have the NI-488.2 and NI-VISA drivers installed? Downloads for both drivers can be found at ni.com/downloads, as mentioned above.
In order to get more traffic for this question, please create a new post and reference the old post if necessary.
Catherine B.
(4,959 Views)
