PCI-GPIB 188513E-01 and Windows 10 and PCIe
We are using a computer (OS Windows XP) connected via a PCI (PCI-GPIB/TNT5004 188513E-01) to an Agilent DMM. The current drivers are NI-VISA version 4.3 and NI-488.2 version 2.52.
We want to replace this computer with a new one and OS Windows 10. Presumably the new computer only has PCI Express slots. We assume it is necessary to replace the PCI-GPIB 188513E-01 board with a one suitable for PCI Express. What would that board's name be? Or is there another option?
Andreas.
(1,704 Views)
I believe you had the PCI-GPIB and not the plus version. In this case, your best fit replacement will be PCIe-GPIB (two models - low profile and normal). You could even go with the PCIe-GPIB+ that has an onboard GPIB Analyzer.
https://www.ni.com/en-us/shop/category/gpib-serial-and-ethernet.html?productId=118313
Santhosh
Soliton Technologies
(1,686 Views)
Thank you for your answer.
Currently the PCI-GPIB board is connected to a device via a National Instrument GPIB cable 763061-005 REV C, Type-X2, 2000 04 03.
Can I use the identical cable to connect to the device with a new PCI Express - GPIB board (available via the link above)?
(1,614 Views)
Both PCI and PCIe versions of GPIB cards use the same connector, so, you can use the same GPIB cable for instrumentation.
Santhosh
(1,606 Views)
