03-17-2008 03:58 PM
03-19-2008
03:19 PM
- last edited on
05-10-2026
11:53 AM
by
Content Cleaner
Howdy josiah,
Just out of curiosity, what version of NI-488.2 do you have installed on your Vista machine? Version 2.5 supports Vista. I could not find errata involving the 34401A DMM with older PCI-GPIB cards in DOS or the 34401A DMM under Vista.
Let's try first verifying the NI-488.2 driver version you have installed and then performing an NI-Spy capture log of the communication to your DMM through GPIB messages. Perhaps we can review the NI-Spy capture log and see what the hold-up is.
Message Edited by pBerg on 03-19-2008 03:20 PM
03-20-2008 02:19 PM
03-21-2008 11:02 AM - edited 03-21-2008 11:02 AM
03-24-2008 02:18 PM
03-25-2008
10:10 AM
- last edited on
05-10-2026
11:52 AM
by
Content Cleaner
Howdy Josiah,
In addition to your idea, maybe reverting to an older version of NI-488.2, the GPIB driver, will yield better performance. You mention using the PCI-GPIB card in a DOS environment, which makes me assume that the card is a bit older. I could not find any reported cases where an older rev PCI-GPIB card performs differently on a newer version of the driver, but it might be worth a shot.
Another thing you might want to do is quadruple check to make sure the PCI-GPIB settings under your Vista OS perfectly match what they were under DOS (EOI, EOS, Bus Timing, etc). Any discrepancy in GPIB settings could cause problems. You will want to verify these PCI-GPIB settings both in MAX (Start»Programs»National Instruments»Measurement & Automation) and the GPIB Configuration Utility (\National Instruments\NI-488.2\Bin\GpibConf.exe).
03-26-2008 02:31 PM
