PCI GPIB and 64 bit Windows 7
Hi
I have a Windows 7 OS which is 64 bit. The motherboard has a PCI slot.
I have have just purchased a used PCI-GPIB Controller Interface Card 777158-01 (183617G-01). I intend to control an instrument using Labview 2017 via GPIB.
Does anyone foresee any problems with this configuration ? For instance installing such a card on a 64 bit OS ?
Regards
Barry
(3,049 Views)
Hi Barrys,
I checked briefly the driver docummentation and it should work fine. Do you encounter any issue?
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(3,001 Views)
Hi ...
I managed to insert the card and after installation of some software was able to control the instrument using GPIB.
No problem !
(2,987 Views)
