PCI-GPIB card not found in linux 2.4.22-1.2115.nptl Fedora Core 1
I am trying to install the nigpib driver on a Fedora Core 1 installation of linux (kernel 2.4.22-1.2115.nptl.) The installation script reports the following errors:
Your kernel appears to be configured properly to build NI-GPIB for Linux.
Do you want to proceed? [yn] y
make: `nigpib.o' is up to date.
Copied nigpib.o driver to modules directory /lib/modules/2.4.22-1.2115.nptl/kernel/drivers/char
Devices created.
Probing for PCI-GPIB.
No PCI-GPIB boards detected.
Do you have an AT-GPIB/TNT board installed? [ny] n
/etc/modules.conf is up to date.
Warning: loading /lib/modules/2.4.22-1.2115.nptl/kernel/drivers/char/nigpib.o will taint the kernel: no license
See http://www.tux.org/lkm
l/#export-tainted for information about tainted modules
/lib/modules/2.4.22-1.2115.nptl/kernel/drivers/char/nigpib.o: init_module: Device or resource busy
Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters.
You may find more information in syslog or the output from dmesg
/lib/modules/2.4.22-1.2115.nptl/kernel/drivers/char/nigpib.o: insmod /lib/modules/2.4.22-1.2115.nptl/kernel/drivers/char/nigpib.o failed
I have moved the PCI-GPIB card to the first PCI slot with no differences in the error messages I recieve. When I run dmesg I recieve the following information:
unable to get major 31 for gpib
Any help would be appreciated.
Message 1 of 1
(3,416 Views)
