Revision K of the PCI-GPIB board is keyed for both 3.3V and 5V slots, see http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/1dfe63598a43e28a86256a300050d97e?OpenDocument. Be sure that you have loaded the NI-488.2 Driver before you put the card in the system. If you have not done this, delete all references to the card in Device Manager, remove the card, and install the 488.2 drivers before continuing. Then, put the card in a slot and boot the computer. Windows should then detect the card and attach the drivers to the device.
Scott B.
Applications Engineering
