PCI-GPIB on Windows 10
Hello Everyone!
We are running MS Workstation with PCI-GPIB and would like to switch to Windows 10.
Is PCI-GPIB compatible with windows 10? I have installed NI 488 drivers and the PCI card is showing up properly. Does it mean that there is no compatibility issues between Win 10 and PCI-GPIB?
The MS Workstation is not able to see the instrument but the PCI-GPIB is seen in the device manager. I need to make sure that Win 10 and PCI-GPIB are compatible so that I can look the issue elsewhere.
Thanks for the replies!
(2,161 Views)
Well, the PCI-GPIB is still listed as a supported device for NI-488.2 21.0 (just released, Readme), so I am left to assume it is supported in Windows 10 assuming you are using NI-488.2 15.5 or newer (NI-488.2 Operating Systems Support).
(2,146 Views)
