PCI-GPIB
I am using a PCI-GPIB to Communicate with my spectrum analyzer is there a way to get a screen shot of what I’m seeing on my spectrum analyzer into my labview program or maybe a separate file?
(5,265 Views)
Perhaps. Have you read the instrument manual? That information would be in there. Commands to capture the screen and transfer it are always instrument specific and are not at all related to your subject. You have not even provided the make and model of the instrument so how can anyone really help?
(5,256 Views)
Oh sorry I forgot to add that in my Instrument is a Agilent E4440A Spectrum Analyzer. and an Agilent E4418B power meter. Thanks.
(5,248 Views)
Also i have seach through the manual to try to find a command but all i found was a Measure, Read, and Fetch. And none of those commands would do what im trying to do.
(5,245 Views)
Have you tried asking Agilent?
(5,239 Views)
You need to use the :MMEM:STOR command to store the screen image to file. This will save it to the PSA's internal hard disk.
Example::MMEM:STOR:SCR "C:\TEMP.GIF"
Then, to get it to your PC you would query the memory. E.G.: :MMEM:DATA? "C:\TEMP.GIF"
The manual has information on the format of the data that is returned from the DATA? command.
(5,229 Views)
Thank you very much I appreciate that I will try it. Thanks
(5,221 Views)
