PCI-IEEE488 from Keithley isn't detected by MAX1.0
I try to install a PCI IEEE488 card provided by Keithley and use it with LabVIEW5.1 but the Measurement & Automation Explorer(v1.0) give me an error like this:"GPIB interfaces not foud",What's happening?
(3,433 Views)
NI-MAX was designed to work only with National Instruments' drivers and devices. If you are using a third-party GPIB DAQ or other device then MAX will not recognize it. This should not affect LabVIEW's ability to use the device though assuming the board is installed and functioning properly and that a DLL is provided for software interfacing.
Ryan Mosley
(3,433 Views)
