PCMCIA-GPIB cable schematic
Hi:
Where can we obtain the cable schematic for the cable that is used with NI's PCMCIA-GPIB interface card.  We want to ring out the cable to see if the cable we had is bad.
Thanks.
(4,849 Views)
The information we have on our PCMCIA-GPIB cables is available on the PCMCIA-GPIB Cables Product Page.  If you need more specific information that is not available on our website, I recommend e-mailing support@ni.com, or calling 1-866-275-6964 to talk to one of our support engineers.
Lauren
Applications Engineering
(4,828 Views)
Hi:
I don't see the document on the pin mapping from the serial connector to the GPIB connector for that cable.
Thanks.
(4,825 Views)
Ooops.  Sorry.  I didn't meant serial.  I meant PCMCIA.
(4,824 Views)
It sounds as if the specific information you are searching for is not available on our website.  As I mentioned before, you should consider contacting our support engineers.  In the meantime, I will continue to look and see if I can find anything.
Lauren
(4,796 Views)
