PHD 2000 pump
Hey, I try to control the infuse flow rate of the PHD 2000 pump. I can set the flow rate through pump panel but not through LabVIEW PHD driver (specific to this pump) downloaded from ni. com. How to set the infuse rate of PHD 2000 pump through LabVIEW?
(5,077 Views)
As you can see, the driver is unsupported so the quality is a bit suspect. Do you get any errors? Are you sure that you have the correct com port settings and that the cable is the correct type? Can you communicate with it with a program from the vendor or with a program such as putty?
(5,072 Views)
