PSU40-38 control wiht pc
if someone has an idea how to realize the communication between the PC and gwinstek PSU40-38 via Ethernet. I would like to control the PSU using their own applications but can not find the appropriate syntax for instructions?
greeting
(3,716 Views)
I'm seeing that the product page mentions that they have LabVIEW drivers available for download.
http://www.gwinstek.com/en-global/products/DC_Power_Supply/Programmable_Single_Channel_DC_Power_Supp...
Have you looked into that?
(3,678 Views)
Yes,  I'm  seen, but  not working on PC  from  my program...  any idea?
(3,671 Views)
Can you communicate with the device using NI-MAX?  Please attach the program showing us what and how you are attempting to communicate with the device.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,667 Views)
so use hercules program to send and testing koomunikacije with the physical device.
I would like interface for communication via Ethernet.
My idea was that I could read out and parametrisem value on the unit via a PC and you can read out the value. such a program have not found so I would then probably worked his program for this but we need some communication for it.
(3,665 Views)
What went wrong?
I looked at the driver and although rather simple they look complete.
Did you fill in the correct visa resource name for your ethernet device?
what was the errormessage etc.?
greetings from the Netherlands
(3,658 Views)
