PXI-8330 WinXP Driver support
I have a PXI System which I need to connect with a VXI system. The PXI System is a PXI-1045 Chassis, PXI-8105 Controller and PXI-8330 MXI-3 Copper card. In the VXI system I have a VXI-8340 MXI-3 Card and a VXI intrrument to be driven.
Inserting the PXI-8330 card into the PXI chassis the first time with no cable connected, it did not appear in MAX and no hardware driver request was made. With the cable connected between the 8330 and 8340 a hadware driver is now requested by Windows and the device appears in MAX, as does the remote VXI chassis, but the information for the 8330is incomplete and the remote chassis appears to need a chassis config file.
So where would I find the driver for the PXI-8330 that WinXP is looking for? Im guessing it is either part of PXI Platform Services or System Configuration  of which I ve Version 15.1 and 5.6 respectively and neither appears to have a suitable driver making me wonder if it was unsupported by then. Ive searched all the Readme files for both packages , as far back as they are made available and can't find the cut-off point.
Message 1 of 1
(1,183 Views)
