04-17-2025 02:15 PM
From the spec doc:
CAN_H, CAN_L bus lines voltage |
-27 VDC to +40 VDC |
Can I generate a CAN signal inside this voltage range or the equipment is just able to handle these values when receiving some CAN messages?
Thanks.
05-02-2025 07:54 AM - edited 05-02-2025 08:04 AM
The PXI-8512 is using a TJA1041 high speed CAN transceiver, the specs of the transceiver can be found here.
For the future you can find the chips inside any modules on the spec sheet of the module its self. I found the transceiver chip under Physical Characteristics here.
My understanding is, the chip can receive voltages in the range of -27 VDC to +40 VDC, as long as the potential difference of CAN_L and CAN_H is within the ranges shows in the spec sheet.
With regards to signal generation, I believe this is driven by the power method used. Sorry I don't have a concrete answer, I believe you will find what you're looking for in the TJA1041 spec sheet.
Dom
05-02-2025 09:28 AM
HI,
I have been doing some more digging and my understanding is that the PXI-8512 can NOT generate signals in this range.
What you're referring to in the spec sheet is not the signal generation range, but rather the absolute maximum ratings for the pins:
The wide voltage tolerance range is important because:
So while the TJA1041 can survive exposure to voltages from -27V to +40V, it doesn't actively generate signals at those extreme voltage levels during normal operation.
Hope this helps, let me know if you need any more info.
Dom
I live for Kudos
