PXIE 6363 - NIMAX Waveform
In the past, I did use the waveform capability in a digital output P.00 using DAQqmx (Python Wrapper) to emulate a I2Cdigital signal (Timing Task).
Now I would like to create a non-periodic pulse train by sending a bool array with NIMAX, in the same fashion I did in python. Does NIMAX implement this feature? If so could you explain how to do it? I don't see the way of setting an array in NIMAX.
Thanks in advance,
Jaume
(468 Views)
No, the DAQmx Test Panels do no support custom Digital Waveform generation.
Santhosh
Soliton Technologies
(450 Views)
