PXIe 8431/8 on win 7
Dear members,
I would greatly appreciate if somebody helps me out the issue im faceing.
We bought NI PXIe 8431/8 Serial device and I tried to install its driver on win 7 after setting the hardware properly (put the pxi 8431 on 2nd slot).
Everything passed ok when i installed s/w provided by NI and after finishing it asked me to restart computer and i did.
Computer finds PXIe 8431/4 exactly by its name. Hoverwer the problem is it has 8 ports, nothing appeared.
I mean I had to able to have 8 port to open but no ports available.
And I did this steps on Win XP and everuthing is OK. I can open 8 ports and write/read.
Could you pls tell me what is problem with Win 7? On the disk of the PXIe 8431/8 there is written that win 7 supported.
No idea what to do... I cannot downgrade my OS cuz its licenced.
Thanks a lot.
(4,425 Views)
I assume you are running NI-Serial 3.5.1 this version Does have support for Win7.  Support for PXIe devices was not added until version 3.6. available here
(4,416 Views)
Thanks for reply, Jeff.
But Im trying NI-serial 3.9.1 version. Forgot to post version.
(4,409 Views)
hmm  ,  This sounds very odd.
Can you post snips of device manager ports and MAX ports?
(4,400 Views)
