Parallel port accessing
Hi ,
I am trying to access the parallel port and use it as a general purpose I/O , i used VISA  , but it only access 8 bits (pin 2->9) and pins 11 , 12 must be grounded.
I want to use the pins from (1 to 17) as Inputs and outputs.
I am using labview 16.
Thank you.
(3,748 Views)
Hi hosa200
here is a link that might help
http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB
have a great day
(3,704 Views)
Hi andr3s ,
Thank you for your effort.
I already checked this link and tried the first method which is great but it only output signal from 2 to 9, so I can't get input to the system.
The second and third methods use an old VIs which not supported by my LabVIEW 16.
and thank you again for your effort
(3,700 Views)
You should be able to change the property node from write to read in order to read the data bits from the printer port.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,681 Views)
