Parallel port and stand alone application
I'm trying to build an application that need to generate a TTL pulse using the template found at
http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB and the methode 1.
The system works fine on the computer I wrote the application. However, after building it as a stand-alone application and installing on another computer, the Visa resouce cannot find any of the serial/parallel ports. What have I done wrong?
Thanks for your help!
Olivier
(4,127 Views)
Did you include the VISA runtime when you built your installer? What about MAX?
(4,120 Views)
OD,
Verify that your broken system has NI-VISA installed and that you can see your serial port in MAX under Devices and Interfaces
Peter Flores
(4,098 Views)
