Parameter out of range
HI
I get "Parameter out of range" in SR830 driver.
I tried the possible solution i could. figure.
Pls guide.
Message 1 of 8
(7,466 Views)
Impossible to say without knowing which driver function you are using or the values you are passing to the function.
Message 2 of 8
(7,449 Views)
SR830-Adapted to Serail Comm
Kindly look into the driver to know the Commands being passed .
I get the error at Initialize,in Error Vi.
Message 3 of 8
(7,438 Views)
The error vi is just reporting that the instrument has detected an error condition in its programming. After clearing the error, do you get it when just running the initialize function? Have you used I/O trace to capture what is being sent?
Message 4 of 8
(7,432 Views)
Yes checked in IO TRace,it is because of SNAP command -Timeout is thrown.But i have already enabled "/ code" for it but why then it is still throwing TO error.
Message 5 of 8
(7,425 Views)
Are you sure the user data is correct?
Message 6 of 8
(7,418 Views)
I have added Serial Config,Term Char and used LOCL2 between ÖUTX0,*IDN?
These are the only changes i have made to the driver SW.
Message 7 of 8
(7,412 Views)
That doesn't answer the question. The User Data must say 830. You can leave this VI open and probe the terminal to read the value.
Message 8 of 8
(7,399 Views)
