Parse errors in ib_linux.h when I try to compile C code for GPIB in Linux.
Keep getting parse errors starting at line 63 of ib_linux.h when I try to compile C code linked
to the drivers. Using ver 0.6 driver, compiling using gcc name.c cib.o -o name, and I have
ugpib.h as an include in the c code. The Linux box currently has the 2.2 kernel running.
Any ideas?
(3,274 Views)
Hello-
It shouldn't be necessary to compile by hand. After the 0.6 driver is untarred, there should be an INSTALL script to run. Be sure to "su" to have root permissions before running this script. It may also be necessary to "chmod" the INSTALL file before doing a "./INSTALL"
Randy Solomonson
(3,274 Views)
