Phase noise measurement with Agilent E4440A
Yeah, I have checked with the manual of  the instrument.
Message 11 of 22
(3,350 Views)
Then it would appear that whatever changes you made to the VI messed it up.
Message 12 of 22
(3,347 Views)
But I still can't find the problem caused the failure of the measurement.
Message 13 of 22
(3,338 Views)
Hey Colin,
Which of the below shipping examples for this driver did you start with in order to create your Agilent ESA PSA Phase Noise Log Plot Measurement VI? The error that you are receiving is usually thrown when an instrument receives an unknown command. If you believe that the command string that you are writing is correct from what you have read in the programmers manual, then it might be a good idea to contact Agilent and ask them to verify it for you. Also, if you are looking to add extra functionality such as adding a decade table, then you will need the commands to return this table information and you can then display it in a LabVIEW array or other front panel control.
I hope this helps. Have a good weekend!
Lars
NI R&D
Message 14 of 22
(3,297 Views)
Hi Lars,
Thank you for your reply.
The error occured in the subVI "Configure Log Plot.vi", the error is "-113, undefined header"(see attachment), could you help me to analyze the error?
Message 15 of 22
(3,283 Views)
Hi, Colin,
Maybe you already resolve the problem. here is what I have found out: the command ":LPL:FREQ:SPAN:BAND:RAT:AUTO ON; " should be ":LPL:FREQ:SPAN:BAND:RES:RAT:AUTO ON;" for auto ratio configuration. otherwise, add "RES" in between "BAND:RAT" for manually setup.
It works find with my software without the "undifined file header" error.
regards
CQ
Message 16 of 22
(3,169 Views)
Hello Colin,
The manual states that "RES" is an optional instruction.  That being said, would you mind removing the "RES" command and let us know if you experience or don't experience the "undefined file header" error?
Shawn S. | NIC
Instrument Driver/IVI PSE
Message 17 of 22
(3,140 Views)
Hi, Shawn
I tested with my PSA. although "RES" is an optional instruction, the system gave me "undefined file header" error when I removed it. Don't know why. but it just fixed the problem.
best regards
CQ
CQ
Message 18 of 22
(3,132 Views)
Which firmware version are you using?
Shawn S. | NIC
Message 19 of 22
(3,118 Views)
the firmware is A11.04.
CQ
Message 20 of 22
(3,083 Views)
