Place HP 34401A in Local Mode with GPIB-USB-HS
I'm using LabVIEW 2010 SP1 to control the HP 34401A with the NI GPIB-USB-HS device. I'm using the built-in 34401A instrument I/O drivers.
If I have everything connected, the 34401A will immediately be placed in "Remote" mode when I run my software. However, I'd like the ability to use LabVIEW to force the 34401A to "Local" mode. Unfortunately I haven't been able to find a way to achieve this. I've tried Close.vi, but that doesn't have an effect.
Here's my intended operation if it makes things more clear:
  1. Launch the software
  2. Initialize the 34401A
  3. Place the 34401A in 4W-resistance measurement mode
  4. Switch the 34401A to "local" mode so that the end user can adjust a trimpot until the desired resistance is obtained while seeing the resistance value change on the 34401A
  5. Re-initialize the 34401A when I need to switch to a different measurement
Alternatively, is there a way to get the 34401A to continuously display whatever measurement it's taking while in remote mode?
Ian Williams
Linear Applications Engineer
Precision Linear and Sensing Products
(7,674 Views)
Why don't you try the VISA GPIB Control REN function?
(7,672 Views)
Dennis,
I actually needed the opposite - enable Local instead of enable Remote. Regardless, your suggestion led me to digging around in the GPIB commands and I found what I needed. Thanks for the tip!
Ian Williams
(7,668 Views)
Accepted by topic author leto_II
The function I mentioned does exactly the same thing except you don't have to do that goofy parsing of the address. It's a VISA function and you should have just used the search button to find it (and turned on Context Help) to get the explanation of what it does.
(7,663 Views)
Dennis,
I apologize if I offended you. I found the function you suggested and it's indeed a more elegant solution. Many thanks for the help.
Ian Williams
(7,659 Views)
No offense was taken.
(7,653 Views)
