Place Xantrex 18-30 in Local communication mode
We have the NI GPIB-usb-HS device and  using it with the ni communicater under max.  I need to place several of these Xantrex 18-30 supplies in local communication mode so we can use these supplies as desktop supplies.  pauljal@cox.net
(3,317 Views)
Do you want to use MAX always or do you have a programming environment available?
greetings from the Netherlands
(3,314 Views)
We just need to use these supplies as bench-top, stand alone, supplies.  They were previously used in test systems and are now all in REM communications mode.  They need to be reset to LOCAL mode.  I don't recall how they were reset.  This has nothing to do with remote or local sense.  Thank you.
(3,308 Views)
Have you simply tried disconnecting them and cycling power? Otherwise, you only need to issue a GTL (go to local) command.
(3,305 Views)
