Please help, urgently Error 1 occurred at Scan From String (arg 1).
I am communicating with the AT Trainer 5000 via serial port to USB converter.
I installed all drivers of converter successfully and it is shown in MAX as com port. I also installed VISA software.
I am using labview 2013 version.
When I connect the hardware to PC via usb to serial converter, try to run the program for seeing of real time graphs, I am receiving this error Error 1 occurred at Scan From String (arg 1) whereas there is no waveform shown in waveform chart.
Also read buffer didn't show an incoming data at read buffer.
Other details for this error is
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Also pics of error is:
Program is also attached. Please checked the also.
Expert please help me how to get rid of this error.
(4,352 Views)
