Plug and play devices
I am trying to interface Keithley 2701 DMM with Labview signal express'15. I tried to download Keithley drivers from NI and found two different drivers ( http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:idr/q/keithley%202701/ ).
I installed the driver in LabVIEW, Measurement Studio for Visual Studio, LabWindows/CVI link as it is an .exe file. I was successful in communicating with the DMM as there were no errors in communicating the parameter values such as voltage, resistance, current etc. The deficiency with this driver is that, it doesn't support getting data from the multiplexer card (7708) of the DMM.
The other driver in the LabView (see figure driverList.jpg) link is a plug and play driver and provides support for the multiplexer card. I tried installing the driver following the instructions in the page http://www.ni.com/devzone/idnet/inetinst.htm but couldn’t find the driver in MAX after the installation.
I don’t have a clue what the issue is. Can somebody help me in resolving the issue?
Thank you very much for your patience.
Thank you,
Srinivas.
Message 1 of 1
(3,619 Views)
