Presentation does not recognise my NI P6008 USB device, although Windows does
I'm trying to get presentation to recognise the NI P6008 input device, so I can use it with a script, but although it appears to have recognised it in Windows and in the NI DAQ base device list, it doesn't appear i presentation.  I was wondering if someone could help me with this.
Best,
Shaun
(3,399 Views)
What do you exactly mean by presentation here?
(3,398 Views)
Its a programme by neurolabs, which registers user input.  It's supposed to be compatible with the NI-P6008, but it doesn't seem to recognise it
Shaun
(3,387 Views)
Why would you use DAQmx base? Is that really what this Neurolabs requires? If so, you should probably contact them about the problem. Otherwise, install the normal driver for windows - DAQmx.
(3,376 Views)
