Problem With NI Cardbus-8310
 I try to Install a NI Cardbus-8310 in a Toshiba Satellite A105 and did not work properly,  we follow the installation instructions and we try several times and we have the same problem.
    The PCI Bridge Device did not found the proper drivers,   what can I do to fix this problem ??
Best Regards
(3,363 Views)
Hi FREREY, the NI Cardbus-8310  doesnt work with all Laptops. And it apears that the Toshiba Satelite A105 is one of those in which it will not work.
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(3,328 Views)
