Problem doing group GPIB reads with agilent N6700B
I am unable to readback proper voltages  of 2 power supply outputs in channe 1 and 2 of Agilent N6700B mainframe at GPIB address 1.
Expecting to read values 5 and 15 but observe very small values. I have the source code but did not know to attach the this post.
Uding NI-SPY do not observe any bus errors.No VISA errors based on source debug using probes in LabVIEW.
Any help wlould be greatly appreciated.
(3,407 Views)
Attaching file(s) is simply a matter of clicking on the 'Add Attachments' right below the message body.
Another quick thing to debug is to use a DMM on the ps outputs and see what that reads. You should also use the error query function to see if the instrument itself reports any error.
(3,406 Views)
Continue here
(3,401 Views)
