Problem of connection between Signal Generator R&S SMG and GPIB
Hello everybody,
I have many instruments that I control with GPIB including the signal generator R&S SMG, and I can communicate with the SMG but after a time, MAX NI doesn't recognize it and I can't do anything with it in local mode, It doesn't respond to any button, so to control it, I must turn off the device and then turn on to control it in local mode, but NI MAX doesn't recognize it. But if I wait 5 minutes before turn on the device, MAX recognize it. So I am confuse and I don't know why it happens.
 If you have a solution, it will be perfect,
Sorry for my english,
Flo
(5,047 Views)
How many other instruments?  Are you sure they all have unique addresses?
This sort of sounds like an issue with the firmware of your device.  You should probably get a hold of R&S tech support.
(5,042 Views)
Thank you for your answer
I have two others instruments, a spectrum analyzer which uses the adress 21, and a programmable filter which uses the adress 8, and the adress of the SMP is 21, so I'm sure they have unique addresses. I rensigner me if it is the firmware and I tell you if it is that,
Flo
(5,037 Views)
Flo
Your spectrum analyzer and SMP are both set to 21?  Those are not unique.  I'm really hoping you made a typo there.  Well, not really because that would be your problem.
(5,035 Views)
No sorry for this mistake, the adresse for the SMG is 28,
Flo
(5,029 Views)
I use a driver in LabVIEW which correspond to the driver of the SMH (R&S), maybe when I use this driver, there are a problem, but normally this driver is compatible,
Flo
(5,027 Views)
Try swapping the GPIB cables.
Also make sure that they are connected securely.
(5,014 Views)
