Problem of using pmcadll.dll (pmca get data) of Amptek MCA8000A
Dear asddf,
thank you in advance for your fast reply!!!
But, I need also 4 the 4 sub vi present in the vi that you sendo to me...
Pmca Power Up.vi
Pmca Get Device type.vi
Pmca Connect.vi
Pmca Get Gain.vi
Dariush Hampai
Message 11 of 21
(3,656 Views)
I try to use this vi (I create the necessary sub_vi's) but it stop my labview process...
Message 12 of 21
(3,652 Views)
Hi Asddf,
I try to manage your vi, but I have some questions to do:
1) if I try to change the gain, when I ask to the mca (for example by "GetGain"), the mca sends to me a different value... and I find this problem with all the "set" statement;
2) the exit buffer has always the same values... why?
in attachment, you will find a vi modified by me... coul you test it in order to say if I wrong somewhere?
best regards
Dariush
Message 13 of 21
(3,630 Views)
Hi Dariush,
I didn't get your question. But I suggest you use subvis instead of using call library function. All the subvis can be generated from the PmcaDll.dll. In Labview, go to Tools --> Import -->Shared library (.dll) and then follow the wizard to finishing generating all the subvis. If you cann't generat the subvis, I will send them to you.
There is obviously something wrong with the vi to sent to me, I haven't got time to test it. I will do it later,
Message 14 of 21
(3,613 Views)
Dear Friend,
could you please send me these subvis.
Murari
Message 15 of 21
(3,010 Views)
Dear MR2013,
may you sand me your email? I will send you directly the lbraries (I use only sync functions...)
dh
Message 16 of 21
(3,008 Views)
Dear DH,
my email is murari.regmi@gmail.com.
I would appreciate if you could send your your combined working VI as well.
MR
Message 17 of 21
(2,991 Views)
Dear all,
Could you look at the attached Vi. Whenever I use it MCA8000A takes more almost 2 minutes to get the data out and only reads up 512 channels when it is supposed to read 1024 channels. It also sends out an error code -23. Any suggestions will highly appreciated.
Can it be because I am using 32 bot DLL with a 32 Bit labVIEW(LV 2011) in a 64 bit windows (windows 7).
Thanks a lot in advance
MR
Message 18 of 21
(2,950 Views)
I'm sorry for the delay, but I have attended a conference (just today I have done my oral presentation...)
In the next days I will send you by email my vi for PMCA8000A
dh
Message 19 of 21
(2,945 Views)
Thanks. That will be great
Message 20 of 21
(2,943 Views)
