Hello!
I want to contro a Digital MultiMeter with Labview 5.1. The interfece that I must use is RS232C. A byte has to be sent to the DMM and then it answers with 14 bytes. The data protocol is 600 7n2, and helped with an oscilloscope, I know that the DMM recibes the byte and sends the answer, but PC doesn't recibe it.
The DMM has a program that communicates propperly with him. I have seen that when the PC communicates with the DMM, the DC level in the Rx pin increases +5V DC, which doesn't occur when the DMM's program is used. I don“t know what to do, if there is a program that can communicate with th DMM, Labview will be able to do ot too, won“t it?
Thanks!
