Problem while creating a new network device in MAX (oxford mercury IPS-M)
I have a problem when I try to add a new network device in MAX. I'm trying to connect a Oxford Mercury IPS-M supply (http://mymercurysupport.com/sites/default/files/59_UMC0072_01.pdf) to my computer using TCP/IP (no GPIB port on the supply, no RS232 port on the computer). My computer is saying that the IP adress asciociated to the ethernet port is 192.168.1.2. I have put those parameters on the GUI of the supply (setting -> ethernet) :
IP adress : 192.168.1.2
subnet : 255.255.255.0
gateway : 192.168.1.1
The supply seams to be connected, when I do a ping in cmd it works. But when I go in MAX and try : Add Network Device -> VISA TCP/IP Ressources and try manualy entering the IP adress (192.168.1.2) I have this message :
"Could not open a VISA session to "TPCIP0::192.168.1.2::INSTR".
VISA error code 0xBFFF0011
Insufficient location information or the device or ressource is not present in the system"
Any idea?
Thank you
Message 1 of 1
(2,486 Views)
