Problem whith scale x y on waveform from agilent 54624A
I have a problem when I get waveform from agilent 54624A, I use ag546xx driver and ag546xxFetchWaveform.vi. The scale x and y are not correct
(3,623 Views)
How are they incorrect? If you're using a LabVIEW graph to display the data, are you using the Initial X and x increment returned from the function? The amplitude array should plot correctly but the time scale won't be the same unless you modify something. You can either build a waveform data type with the correct t0 and dt or change the graph's properties.
(3,623 Views)
Hello Lorival,
You say that "the scales x and y are not correct". Can you more explain the problem?
Concerning the function "ag546xxFetchWaveform.vi", don't hesitate to modify it until it corresponds to your measurements.
Sanaa T
(3,623 Views)
