Problem with Agilent 34401A
I would like to connect with Agilent 34401a by GPIB. Unfortunelly it doesn`t work. I used adapter USB-3488A from brand Adlink. NI MAX does not read the device. I have got all neeeded drivers. Keysight Connection Expert is seen but it is problem with communication. The adapter is working, I checked it with different Agilent 34401a. Have you any idea why ?
Thanks for the help in advance 🙂
(2,814 Views)
If it works properly on the other system, I would first printout the standard custom report from NI-Max on the working system with that adapter then another for the problem system.  Note any differences between the two machines.  You might find a missing driver or a different setting between the two systems.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,800 Views)
