Hello Randy and Zdenek,
> A spy capture is a great idea. There are two versions of thedriver,
> an IVI driver and a Legacy driver. Try the other type of driver.Let
> me know how it goes.
I have tested 2 different drivers (IVI and Legacy), without any
improvement. But it seems to me, that the latest Version of the Driver
(IVI) is the best, cause i get the correct result always after the
second call. With the other version i can get faulty result up to 10
times and than the correct values will be returned.
I have attached a spy-file where you can see the returning results.
Please have a look at line number 3 and 6. The function return 49,99V
first and then 4,99V (correct).
The function returns two different exponent. The same effect at line
num
ber 9 and 12, which return 3.287A first and than 0.330A (correct).
I have tested the driver on another machine with CVI5.5 running and
the results were always correct. On my system, where i have CVi5.5 and
6 installed, i get the faulty result under CVI5.5, too. So i think
that
the problem is in a direct context with the new Version of
LabView/CVI.
Any ideas?
thanks & best regards
Gregoire
PS: I have switch several HP Power Supply?s to be sure there is no
hardware defect.
[Attachment Capture.spy, see below]
