Problem with VISA control for COM port
I am a new user and i use labView Full development express 7 , I want to interface/controll LeCroy LP 142 oscilloscope with pc through com port ,for doing this I went to ni example finder -->instr-->sampler.llb and run same programme oscilloscope respnse and carries remote operation but when i make a new vi with similar configuration and visa write and read and visa close vis then it does not work i went throgh max to visa intrictive controll then oscilloscope response
i am using windows xp as operating system , what mistake i am doing for making Visa driver through serial com1 port .
thanks
rryadav
(3,846 Views)
It's unclear to me what actual VI you used. There's an almost unlimited number of things that could go wrong with serial communication so it would help a lot if you provided more details on the VI that you tried and the one that doesn't work. Attaching the actual VI that you wrote would be a big help and information on errors generated, etc. would also be nice.
(3,846 Views)
Attached vi which i made. for above problem
(3,846 Views)
I don't see anything terribly wrong. In your write control, you should probably turn on '\" Codes display so that you can type in the termination character. This is usually a CR or LF as the last character in the write string. Without it, the instrument won't respond.
(3,846 Views)
