Problem with running Hantek 6022BE driver/HTMarch.dll in macOS catalina
Hi there
I would like to use Hantek 6022BE driver in Labview 2018 running on macOS. I have a problem with recognizing HTMarch.dll. It seems there is a mismatch between 64 bit labview and 32 bit HTMarch.dll. I would really appreciate it if you could help me with resolving this problem. Please check the attached images.
Ben
(4,851 Views)
Даже когда я установил labview 15 32 бит, я все еще не получал информацию от осциллографа!
(3,266 Views)
