11-16-2007 06:17 AM
11-16-2007 06:57 AM
I think my problem just became even simpler...
How can I output a carrage return to the VISA Write command?
Robert
11-16-2007 07:53 AM - edited 11-16-2007 07:54 AM
11-16-2007 07:42 PM
Thanks Albert,
That solution works off of my USB -> serial port adaptor, but when I compile the app and move it over to a desktop and try to run it through a regular serial port I'm back to square one. MTTY works but the app doesn't... it's no big deal really, I can use a USB -> Serial adaptor but this is the first time I've ever had LESS trouble with a USB -> Serial then with straight serial control.
Thanks again for the help.
Robert.
11-16-2007 09:51 PM
11-17-2007 01:18 AM
I still can't get the desktop Serial port to work, and the USB -> Serial adaptor won't work on it either. I've probed the 6 data lines going into and out of the device being controlled and it seems that every command I send from the desktop is resetting the device. The only difference I can see is that the desktop calls the port a ASRL port and my laptop calls is a COM port.
Any difference between these two?
Robert.
11-17-2007 02:34 AM
11-17-2007 08:03 AM
