Problem writing to FTDI FT245R
I am using the D2XX commands to interface with an FT245R relay board. I can connect, get a handle, get the device details (serial number, etc), get the modem and queue status, etc.
The problem is that I cannot use the FT_'string write' function to change the state of the relays.
UNTIL... I open and close the program provided by FTDI (simple control program for the relays). THEN... it works perfectly.
I don't even have to operate any relays with their program, only use it to open the board one time and then close the program. I only have to do this if the computer has been restarted and can open and close my program as much as I like as long as I don't restart the computer. I have tried all manner of port settings, reset the port, reset the device, tried different time delays, set it to synchronous/asynchronous/bit-bang and everything else that I know. I know that I am connected to the board because I can get the device details but it will not accept my write command until I first use their program to connect to the board. I have read their D2XX programming guide but didn't see any information pertaining to this kind of situation.
Does anyone out there know what command/setting their program contains that would cause this?
(4,368 Views)
FT245R is an IC.
(4,359 Views)
Try this connection as it refers to some of the FT245R chip commands.
Prologix-GPIB-USB-Controller
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,309 Views)
@Minions
Thanks for this. I am using USB, possibly this is the where the problem is at. It just seems strange that I can ping the chip but not get it to send signals to the relay board. I just can't figure out what setting is being made once I open the manufacturer's control program that allows LabVIEW to communicate. I first thought it might be paused and was waiting for an okay or read but none of this seems to work. It is a SainSmart board and works fine once the initial handshake is made, whatever that is. Thanks.
(4,300 Views)
