Problems Interfacing Kiethely 2010 DDM with LAbview
You might want to have Context Help turned on. Move your mouse over the Fomat Value function and in the help window, click on the Detailed Help link. That will explain what the %d does. It's amazing how much you can learn by just reading the manual.Smiley Wink.
As far as the \r\n (not the /r/n as you wrote), the string constant has the '\' Codes Display turned on. You get this by right clicking on the constant. A \r and a \n are a Carriage Return and a Line Feed. They are apparently needed to terminate the command string.
Message 11 of 22
(2,245 Views)
thanks for helping me out but i am still blank on the %d command i even read the detailed help but i was unable to find te answer kindly enlighten me it with the command
Message 12 of 22
(2,243 Views)
The format %d says to take the numeric input and convert to a signed decimal integer string. The exact help topic is Format Specifiers Syntax Elements. In your code with :"Route:Scan (@%D:" and if you had the number 2 as an input, the function would output ":Route:Scan (@2:"
This is basic stuff in LabVIEW. Did you ever take any of the tutorials I gave a link to?
Message 13 of 22
(2,230 Views)
hi
im student, using tha keithley 2010 for scanning GPIB port ....The Kiethley 2010 uses a scanner card with multiple channels (exactly 10 channels) and i want to give the user the freedom to use any of the 10 channels he want how can i do this in labview
i used  Keithley 2010 Scan Config.vi but it has a missing subvi called "GPIB Send Message.vi" if u could kindly upload that as well .... waiting for ur reply ..... kindly help me out for my project
Message 14 of 22
(2,025 Views)
You have to download the entire driver. The link is given.
Message 15 of 22
(2,020 Views)
from where i can get the drive ..... n how can i download the send messege.vi?
Message 16 of 22
(2,012 Views)
Read the thread. The link to the driver is given.
I also gave the link in one of your other posts on the exact same subject before I noticed it was a duplicate.  Ask your question once and once only!
Message 17 of 22
(2,011 Views)
sorry 4 double posting the same messge....thnks a lot 4 ur reply....yes the link is
http://www.keithley.com/support/keidoc_searchresult?keyword=2010&item_type=All
my drivers for kiethley is installed
im actually not understanding  send messege.vi?
Message 18 of 22
(2,005 Views)
on the link page the driver is for labview 6.0........i have labview 8.0
Message 19 of 22
(2,004 Views)
So? You didn't even try to download it and open it, did you?
Message 20 of 22
(2,002 Views)
