Problems at using Aglient 54624A
Dear all,
Are there any vi llb for "Aglient 54624A" which can use RS-232?
i ve' download the instrument driver from Instrument Driver Network, but it's seems can work in RS-232(since the driver haven't told that it can work in RS-232?)
p.s. I've download some examples from Aglient's official website, but it seems can't find the sub-vi s can anybody tell me why?
here is one of the example attach.
(3,477 Views)
Those subVIs that are missing are the instrument drivers for Agilent 54624A. I tried downloading the GPIB instrument drivers and it didn't work. It seems like the program you downloaded from Agilent is referring to ag5462xx Initialize.vi and so forth. Whereas, the IVI instrument drivers are named ag5462x Initialize.vi and so forth. You will have to check with Agilent (where you got the example from), and see if they have any RS-232 based instrument drivers. If not, you can try using the regular GPIB based IVI drivers. You'll have to change your code a little bit to accomodate this.
A.S.
Anu Saha
Academic Product Marketing Engineer
(3,477 Views)
