Problems in communication with TDS 420
The error occurs during the communication with the Tektronix TDS420 oscilloscope.
I´ve test the communication with the NI-488.2 Communicator. The commands *IDN?, ID?, *TST? works properly.
But if I try the *RST command, the oscilloscope changed the settings correct but after a short time the error EAB0 occurs.
Thanks for help
(3,265 Views)
The problem is solved. I used the function ibtmo, it was not included. And I´ve set the timeout to 100s.
Thank you
(3,262 Views)
